AutoCAD 2010/2011/2012
Member
TSIGALAS
Message 1 of 5 (193 Views)
Accepted Solution
Getting a straight on 3D view
193 Views, 4 Replies
08-10-2011 08:11 AM
I have a part rendered in 3D that I need to take measurements of, and the simplest way that I've found is to do a flatshot and get them off of that. The problem that I'm having is that in all the 3D viewpoints of it, there is always some realistic parallax of the part. In that looking straight on, I see the side walls of holes when i should be looking straight through them and theres basically a convergence point to the way I'm looking at it.
I'm needing to see this straight on to test for measurements and fit with components. Any ideas how I can fix this so I can take accurate flatshots again?
You're probably in a PERSPECTIVE view, if you are, switch to Parallel, and avoid clicking on the "Home" icon on the ViewCube, because that automatically tosses you back to Perspective. (hint; right click on the ViewCube to change Perspective)
*Expert Elite*
JDMather
Message 2 of 5 (176 Views)
Re: Getting a straight on 3D view
08-10-2011 11:25 AM in reply to: TSIGALAS
Is there any geometry (a hole would be good, a planar face even better) that you can reset the UCS on and then set the view to the current UCS?
Can you attach the file here?
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
*Pro
nestly
Message 3 of 5 (166 Views)
08-10-2011 01:11 PM in reply to: TSIGALAS
Member
TSIGALAS
Message 4 of 5 (161 Views)
08-10-2011 01:15 PM in reply to: JDMather
Resetting the UCS wasn't the issue. It turns out I was in perspective view and not in parallel view. Thanks though.
Member
TSIGALAS
Message 5 of 5 (159 Views)
08-10-2011 01:16 PM in reply to: nestly
Thanks!!!! That got it, I was in Perspective view.
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
