AutoCAD 2010/2011/2012
tmann_008
Message 1 of 15 (2,394 Views)
G-code from 3D mesh model for CNC 3axis machine
2394 Views, 14 Replies
09-25-2012 08:54 AM
Good morning folks. I have been struggling with an issue to create a G-code from
an AutoCAD desktop 3D model of a 1911 pistal grip saved as a DXF file. I am new
at this and have a CNC 6040 3 axis routing machine. I have tried to load the DXF
file as an import but the file is not recognized by the Mach3 software. I have
downloaded a lisp comand for my AutoiCAD program which is supposed to generate a
G-code within Autocad but It doesnt recongnized some 3D elements. I am having a
dificult time getting the generater to read a "mesh" 3D form to generate a
G-code. I hope this doesnt sound all too confusing... the bottom line is I cant
seem to get a G-code out of a 3D CAD form.... has anyone had a similiar
problem and has found a way to generate smoothly a G-code from an AutoCAD 3D
form? I would apreciate some assitance with this mater.
*Expert Elite*
Patchy
Message 2 of 15 (2,390 Views)
Re: G-code from 3D mesh model for CNC 3axis machine
09-25-2012 09:00 AM in reply to: tmann_008
Try turning 3d mesh to solid then use STL.
Attach your .dxf here and let's see.
tmann_008
Message 3 of 15 (2,387 Views)
09-25-2012 09:11 AM in reply to: Patchy
here is the DFX 3d Im trying to edit now. I just cant seem to get a G-code or recognizable "object". (The DXF file was too large so I am attaching it as a dwg)
tmann_008
Message 4 of 15 (2,383 Views)
09-25-2012 09:18 AM in reply to: Patchy
fyi; here is a comment I got from a CNC FORUM
"If it's a solid model, export it as an .stl and import the .stl into a 3D CAM
program. Very few CAM programs can read a .dxf of a 3D solid.
You'll need
a CAM program like MeshCAM or Cut3D, or CamBam.
*Expert Elite*
Patchy
Message 5 of 15 (2,375 Views)
09-25-2012 09:42 AM in reply to: tmann_008
Use FreeMill, it's free
Your drawing wasn't simmetrical, I guess that's why it failed.
tmann_008
Message 6 of 15 (2,369 Views)
09-25-2012 09:47 AM in reply to: Patchy
Fantastic ! Thank you much. I'll try this Freemill
tmann_008
Message 7 of 15 (2,337 Views)
09-25-2012 12:46 PM in reply to: Patchy
I'm still having trouble with that file to read solid objects. Here is another file. Hope you still have a chance to see this.
Tony
*Expert Elite*
Patchy
Message 8 of 15 (2,329 Views)
09-25-2012 01:34 PM in reply to: tmann_008
Did you draw these ?  They are not the same location therefore no watertight surface can be made.
tmann_008
Message 9 of 15 (2,320 Views)
09-25-2012 01:44 PM in reply to: Patchy
Thats what I am finding out that they are not watertight. Is there a way to make them watertight ? These where some grips I downloaded from a CNC web site... trying to make some grips on this used 3 axis router i have and been struggling with g-code.
tmann_008
Message 10 of 15 (2,318 Views)
09-25-2012 01:47 PM in reply to: Patchy
these are the files i tried.
Announcements
Need installation help?
