AutoCAD 2010/2011/2012
Member
apec_engineering
Message 1 of 5 (4,834 Views)
Function keys customization
4834 Views, 4 Replies
06-02-2011 01:01 PM
Can anybody help?
Using the CUI editor I have tried to customize the function keys in Autocad 2012.
The default for each of the keys is noted here:
F4
Command:  <3DOsnap on>
F6
Command:  <Dynamic UCS on>
In Autocad 2006 I have the keys customized to do the following:
F4
Macro:  '_zoom_p
F6
Macro:  _cen
Can anybody help?
That comes with Autocad, it's temp. override keys, don't mess with it. When you do as I showed you, drop it at the "SHORTCUT KEYS"  it will work.
Patchy
Message 2 of 5 (4,824 Views)
Re: Function keys customization
06-02-2011 01:34 PM in reply to: apec_engineering
Command CUI, see image (it's from 2010, for 2012 same steps)
Member
apec_engineering
Message 3 of 5 (4,810 Views)
06-02-2011 01:54 PM in reply to: Patchy
My screen snip from Autocad 2012 cui is attached.
Patchy
Message 4 of 5 (4,801 Views)
06-02-2011 02:07 PM in reply to: apec_engineering
Member
apec_engineering
Message 5 of 5 (4,782 Views)
06-02-2011 02:26 PM in reply to: Patchy
Fine it worked now.
Drag and drop to the Shortcut Keys section.
Don't click on the 3 dots button.
Just type the key combination into the Access Key(s) box (i.e. F6 or F4)
