AutoCAD Forum
free Scriptpro for 2014
19 REPLIES 19
Message 1 of 20
Jason-Cad-123
11211 Views, 19 Replies
Can you add in the link to the autocad site to downloan scriptpro
19 REPLIES 19
Message 2 of 20
nicklas
in reply to: Jason-Cad-123
Yes please repair the download links for ScriptPro AutoDesk!
All of the following links are broken!
32 bit Download:
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=4091678&linkID=9240618
64 bit Download:
http://labs.autodesk.com/utilities/scriptpro/
http://autodesk.blogs.com/between_the_lines/2012/06/scriptpro-for-autocad-32bit-and-64bit.html
Best Regards
Nicklas
http://nirklars.wordpress.com
Message 3 of 20
Jason-Cad-123
in reply to: nicklas
Message 4 of 20
also can not find utilities and search does not come up anything
Message 5 of 20
pendean
Message 6 of 20
dmfrazier
Message 7 of 20
I was also looking for it today, specifically 2.0.3 since this one can run the core console.
(I had only 2.0.2. since we just moved from AC2012 to AC2014)
Message 8 of 20
Jason-Cad-123
in reply to: pendean
How can I load up my own scripts into this scriptpro. And can it run a macro that I have recorded using action recorder
Message 9 of 20
pendean
SCRIPTPRO is an external application, you run it outside of AutoCAD.
No, it does not directly handle content from action recorder.
Message 10 of 20
dmfrazier
"And can it run a macro that I have recorded using action recorder[?]"
It can only run an action macro ("not directly") if it's possible to run one in a script, and I think that is possible (although I've never done it) based on this Help entry:
http://docs.autodesk.com/ACD/2013/ENU/files/GUID-6A031D0B-58C9-43E3-8130-F390E9D319A9.htm
So, the first thing to do is add your macro into a script and see how it goes.
Message 11 of 20
adoinc
I try all the posted link, but it redirect to Autodesk feedback community! is anyone know where I can download the scriptPro?
https://beta.autodesk.com/oid/login.html?msg=Session_Expired&ref=/project/article/admin/item%2Ehtml%...
thanks
Message 12 of 20
snowman_427
in reply to: adoinc
Yes, I also need the 64bit version of ScriptPro.
Every link I can find is leads to this Autodesk Feedback Community. I have tried to get this Feedback Community to work, but it’s some sort of circle forcing you to sign up for a project I would have nothing to do with. Then it leads nowhere and is incapable of answering even a simple question.
Where is the download for the 64bit version of ScriptPro?
Message 13 of 20
Dale.Bartlett
in reply to: snowman_427
Has anyone located ScriptPro 64bit? Dale
______________
Yes, I'm Satoshi.
Message 14 of 20
pendean
in reply to: Dale.Bartlett
Dead and gone. You need to purchase a solution if you are not to writing your own simple BAT/Lisp
Message 16 of 20
joshua.jones
in reply to: paul.frylink
You can also download it directly here: http://images.autodesk.com/adsk/files/scriptpro.exe I tested it on 64bit Win7 and it worked beautifully.
Message 17 of 20
David125
in reply to: dmfrazier
I just install scriptpro 2.0 and I don't see it anywhere on my ribbon. I'm using AutoCAD 2014 Architecture. Can anyone tell me what I can type on the command line to issue command for scriptpro?
Message 18 of 20
David125
Paul,
DId you have to do anything special to get scriptpro to show on your ribbon? Forgot to ask you using a ribbon. I can't get it to show on my my ribbon, I'm using Autocad Architecture 2014 and I don't see the command anywhere. It would help if I knew what to type at the command line too.
David
Message 19 of 20
pendean
in reply to: David125
SCRIPTPRO is an external application launched from outside of AutoCAD. It's not an add-on.
Some of many tips on how to do it, if you must:
http://www.hyperpics.com/tipsandtricks/tips.asp?id=110
http://www.cadforum.cz/cadforum_en/qaID.asp?tip=5091
Message 20 of 20
shacho
Hi PenDean.  I had a look at the BatchinEditor and Datbase.  They look pretty cool.  But can you run your on script file (.scr).  I tried to figure it out and it is not obvious.
thanx
”Boost
