Can you add in the link to the autocad site to downloan scriptpro
Solved by shacho. Go to Solution.
Solved by David125. Go to Solution.
Solved by joshua_jones2. Go to Solution.
Solved by pendean. Go to Solution.
Yes please repair the download links for ScriptPro AutoDesk!
All of the following links are broken!
32 bit Download:
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=4091678&linkID=9240618
64 bit Download:
http://labs.autodesk.com/utilities/scriptpro/
http://autodesk.blogs.com/between_the_lines/2012/06/scriptpro-for-autocad-32bit-and-64bit.html
Best Regards
Nicklas
64 bit link takes me to this address https://beta.autodesk.com/project/home.html?cap=F00BD79F7B704B4D894E2FFC0E71E96C&err=No_Cont_Acs
...and another option:
I was also looking for it today, specifically 2.0.3 since this one can run the core console.
(I had only 2.0.2. since we just moved from AC2012 to AC2014)
How can I load up my own scripts into this scriptpro. And can it run a macro that I have recorded using action recorder
"And can it run a macro that I have recorded using action recorder[?]"
It can only run an action macro ("not directly") if it's possible to run one in a script, and I think that is possible (although I've never done it) based on this Help entry:
http://docs.autodesk.com/ACD/2013/ENU/files/GUID-6A031D0B-58C9-43E3-8130-F390E9D319A9.htm
So, the first thing to do is add your macro into a script and see how it goes.
I try all the posted link, but it redirect to Autodesk feedback community! is anyone know where I can download the scriptPro?
thanks
Yes, I also need the 64bit version of ScriptPro.
Every link I can find is leads to this Autodesk Feedback Community. I have tried to get this Feedback Community to work, but it’s some sort of circle forcing you to sign up for a project I would have nothing to do with. Then it leads nowhere and is incapable of answering even a simple question.
Where is the download for the 64bit version of ScriptPro?
Has anyone located ScriptPro 64bit? Dale
I just install scriptpro 2.0 and I don't see it anywhere on my ribbon. I'm using AutoCAD 2014 Architecture. Can anyone tell me what I can type on the command line to issue command for scriptpro?
Paul,
DId you have to do anything special to get scriptpro to show on your ribbon? Forgot to ask you using a ribbon. I can't get it to show on my my ribbon, I'm using Autocad Architecture 2014 and I don't see the command anywhere. It would help if I knew what to type at the command line too.
David
Hi PenDean. I had a look at the BatchinEditor and Datbase. They look pretty cool. But can you run your on script file (.scr). I tried to figure it out and it is not obvious.
thanx
