AutoCAD Forum
Flatten does not work properly
10 REPLIES 10
Message 1 of 11
Rikkes
13695 Views, 10 Replies
I'm using ACAD (2011) most of the time in 3D. I like to work that way and it goes really fast!
Now, sometimes I want to flatten my 3D drawing and show my obscured lines and make them dashed afterwards. With the flatten command and explode it works fine... but... some lines just move! For example, a block with size 100,200,100 turns into a square with size 100.9 x 199.3, even if I use the command in 100% top view!
That's really annoying! Is there a way to avoid this?
10 REPLIES 10
Message 2 of 11
hwalker
in reply to: Rikkes
I'm not to up to date with flatten, but isn't it suppose to move everything to 0 on the z axis. If so why don't you select all the objects and change their z to 0 after exploding or use the following (Not mine someone else on here made this macro)
^C^C_move;_all;;0,0,0;0,0,1e99;_move;_p;;0,0,0;0,0,-1e99;
Howard Walker
Left Handed and Proud
Message 3 of 11
Rikkes
in reply to: Rikkes
It has nothing to do with that.It's just that it changes size of the parts. It's very difficult to explane...
Message 4 of 11
hwalker
in reply to: Rikkes
Does exploding first WITHOUT flattening keep the correct dimensions?
Howard Walker
Message 5 of 11
Rikkes
in reply to: Rikkes
Bam! That's the solution!
Thx!!!
Message 6 of 11
hwalker
in reply to: Rikkes
You might have to use overkill now as you have eg two squares superimposed on each other.
Howard Walker
Message 7 of 11
Rikkes
in reply to: hwalker
Correct! Now I have different lines onto each other. And in some cases the overkill command doesn't help... ****...
Message 8 of 11
hwalker
in reply to: Rikkes
I've never worked in 3d so this might not work. Try doing the explode, then overkill, then flatten.
Does that help?
Howard Walker
Message 9 of 11
Rikkes
in reply to: Rikkes
Nope, tried it allready Smiley Sad ...
Message 10 of 11
RockyBrown4134
in reply to: Rikkes
FYI..... Not sure what you are looking for exactly, but have you looked at FLATSHOT command? It may be an alternative to getting 2D geometry from a 3D object..
If this response answers your question, Please mark this response as "Accept as Solution"
Rocky Brown
AutoCAD 2020 / Inventor 2020 / Plant 3D
Message 11 of 11
GrantsPirate
in reply to: Rikkes
You might want to explore the Viewbase command and the related commands and stop destroying your 3D model.  Assuming you have the version with that command.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
”Boost
