AutoCAD 2010/2011/2012
Member
LachlanNunn4876
Message 1 of 15 (3,706 Views)
find GPS location info in Autocad
3706 Views, 14 Replies
08-13-2010 12:03 AM
I've got a site plan for a civil construction project. Now I only have two points with GPS location, the format is " E322xxx.xxx, 583xxxx.xxx". Is there a way for me to just based on the linear dimsion in Autocad, and to work out the GPS location in the same format of more other points on the site plan?
Many thanks for your help.
just position the data in AutoCAD using those 2 coordinates then you can querry the rest of the data and get similar coordinate information
markdoel
Message 2 of 15 (3,704 Views)
Re: find GPS location info in Autocad
08-13-2010 12:48 AM in reply to: LachlanNunn4876
JDMather
Message 3 of 15 (3,658 Views)
08-13-2010 07:54 AM in reply to: markdoel
Can you post a file demonstrating this technique?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Member
LachlanNunn4876
Message 4 of 15 (3,599 Views)
08-15-2010 02:50 PM in reply to: markdoel
Many thanks Mark!:smileyvery-happy:
Member
LachlanNunn4876
Message 5 of 15 (3,589 Views)
08-15-2010 06:18 PM in reply to: markdoel
Mark, can you please give me more info about this issue?
Is there any equation or could you show me an example?
Thanks.
markdoel
Message 6 of 15 (3,588 Views)
08-15-2010 06:21 PM in reply to: JDMather
if you have 2 setting out points you just need to do the following:
select all data
initiate move command
snap to the first setting out point
key in the coordinates of that setting out point.
querry the location of the second setting out point.
if it reports back the coordinates you have been given all is good
if not you will need to rotate the data.
draw a line from setting out point 1 to setting out point 2 (the current location of setting out point 2)
draw another line from setting out point 1 to the correct setting out point 2 (the true coordinates)
use the rotate command to rotate the data into position using either an angle or 3 points
this is how we have always done it and works fine
Distinguished Contributor
jz4all
Message 7 of 15 (3,523 Views)
08-18-2010 03:50 AM in reply to: LachlanNunn4876
Hi
You can do it also in this way:
*First, be sure that UCS on (world).
*If you brought your drawing to another drawing, try to be sure that they have the same units *(m, mm, feet…etc)
*Then select all the drawing.
*Type in command line: align, you will be asked to choose the first point. choose one of the    known points. the destination is to the true coordinate of this point.
*Do the same with the second point.
*You will be asked if you want to scale the drawing. enter (Y).
Now you get your drawing on coordinates and you can get the info about any point.
JDMather
Message 8 of 15 (3,521 Views)
08-18-2010 04:57 AM in reply to: jz4all
Can someone offering solutions simply post an example of GPS solution example?
markdoel
Message 9 of 15 (3,482 Views)
08-18-2010 07:50 PM in reply to: LachlanNunn4876
Valued Mentor
Randy_Culp
Message 10 of 15 (3,459 Views)
08-19-2010 09:22 AM in reply to: markdoel
That assumes that the GPS coordinates are UTM or state plane (or similar). The coordinates on mine are Lat-Long and require a converter to UTM.
http://boulter.com/gps/
http://home.hiwaay.net/~taylorc/toolbox/geography/geoutm.html
