AutoCAD 2010/2011/2012
doben
Message 1 of 6 (296 Views)
Field Data in Sheet Sets
296 Views, 5 Replies
04-29-2010 06:21 PM
Is there a way to have fields with no values assigned to them to display without the dashes? I am using these for a revision table in my sheet set and will fill them out as needed. I went into the properties dialoge box of the sheet set and hit space bar for each field that I wanted blank, but every time I made any other change the dashes returned.
Any help appreciated.
*Expert Elite*
azrdgldr
Message 2 of 6 (296 Views)
Re: Field Data in Sheet Sets
04-29-2010 08:41 PM in reply to: doben
Try using your fields in attributes in a block that way you can delete the #### on the ones you don't need in attribute edit box. I use fields in my sheets sets but not for revisions. That's what works for me.
*Expert Elite*
PaulMunford
Message 3 of 6 (296 Views)
04-30-2010 12:34 AM in reply to: doben
Hold down the 'ALT' key on your keyboard and type 0160 on the numberpad to insert a non breaking space.
The CAD Setter Out Blog @CadSetterOut
Inventor Surfacing | AutoCAD | CAD Standards
Please use the Mark Solutions! Accept as Solution or Give Kudos! Kudos functions - Thank you!
doben
Message 4 of 6 (296 Views)
05-03-2010 12:02 PM in reply to: doben
Thanks Paul - that did the trick.
*Expert Elite*
PaulMunford
Message 5 of 6 (296 Views)
05-03-2010 01:12 PM in reply to: doben
No problem :-)
Here's a few more Links:
http://www.thecadgeek.com/blog/2006/04/20/blank-sheet-set-fields/
http://heidihewett.blogs.com/my_weblog/2006/04/sheet_set_field.html
http://cadtips.cadalyst.com/sheet-sets/ensure-empty-sheet-set-fields-stay-empty
*Expert Elite*
JGerth
Message 6 of 6 (296 Views)
05-04-2010 05:59 AM in reply to: doben
using %% as the field value also works, and is easier than a nonbreaking space
Post to the Community
New Post
Need installation help?
