AutoCAD Forum
Fatal Error
7 REPLIES 7
Message 1 of 8
KevinBurrows
2019 Views, 7 Replies
Fatal Error
I have a client that is running AutoCAD 2012 on a new Windows 7 64-bit laptop but gets fatal errors when accessing certain menus (Xref Manager, Layer Properties Manager, Options, possibly others).  The messages they have seen so far are:
FATAL ERROR: Unhandled Access Violation Reading 0x0000 Exception at 70e6ddaeh
FATAL ERROR: Unhandled Access Violation Reading 0x0040 Exception at 3fc34be4h
Actions we have tried to stop the fatal errors:
  1. Made sure video drivers are current. Turned off UAC and anti-virus.
  2. Installed Service Pack 2 for AutoCAD 2012
  3. Found this KB article about fatal error 0x0000 and followed its directions: link
  4. Found this KB article about fatal errors and menus and followed its directions: link
  5. Logged in as a different user to make sure it was not a Windows Profile issue.
  6. Opened many different drawing files to make sure it was not file-specific.
  7. Followed most of Dean Saadallah's advice about program stability from this forum thread: link  The only things not done on that list is look at Reliability Monitor and create a perfmon report.
  8. Performed a complete uninstall and reinstall as per the directions in the KB article here: link
Interestingly, the first time AutoCAD is run after the full uninstall and reinstall, it performs fine.  No fatal errors accessing the menus.  After closing AutoCAD and starting it again, the fatal errors return and persist for all runs after that.
I would say it is time to format the hard drive and reinstall everything but this computer was just formatted.
Kevin Burrows
Technical Specialist
ECAD, Inc.
7 REPLIES 7
Message 2 of 8
first: that's like a perfect sample of an thread opening and problem description, really really great!
(I will use that as link for some thread openers with just "it does not work") 😉
That are all dialogs depending on Framework. So I would first look if Framework 4.5 is installed and if it is (and no application uses it) I would uninstall it. Next step is to go through all versions of Framework that are installed on that workstation (in the control panel ==> software) and run a repair on them. Last step: let Windows-update do all updates for Framework except any new installation of Frameworks newer than 4.0 (4.0 is ok, but not newer).
Good luck, - alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Message 3 of 8
braudpat
in reply to: Alfred.NESWADBA
Hello
I suspect too a Framework Dotnet problem !?
But you can install (if not already installed)  the SP 2 on your ACAD 2012 ...
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19500680&linkID=9240618
It can't be worse ...
Bye, Pat
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 4 of 8
Thanks for the reply, Alfred. I will have the client try this and report back here with the results.
Kevin Burrows
ECAD, Inc.
Message 5 of 8
sandsbe
in reply to: KevinBurrows
I am getting a fatal error with this tag: 53dfb619h. It happens when I open a drawing with a surface in it. I have a few corridors modeled. I below the corridor is crashing it during open. How do I open without the corridors crashing my software? the file is only 4 MB.
Message 6 of 8
Alfred.NESWADBA
in reply to: sandsbe
welcome @forums.autodesk.com !
Am I right that you are speaking about Civil3D? Then you should now (for your next thread) that there is a seperate forum for Civil3D >>>here<<<.
First copy your BAK-file to a safe folder, you might rename it to DWG and can try to open the previous saved state of your drawing.
Then start Civil3D, start command _RECOVER and select your defect drawing, this will open the drawing and do some drawing-database tests (and repairments if necessary and possible).
Alfred NESWADBA
Message 7 of 8
Update:
We implemented Alfred's suggestions about repairing .NET Framework.  After several days of AutoCAD use, I'm happy to report the issue seems to be fixed.  Thanks, Alfred!
Message 8 of 8
Thank you for your feedback! - alfred -
Alfred NESWADBA
”Boost
