AutoCAD 2010/2011/2012
New Member
PMH1985
Message 11 of 18 (6,847 Views)
Re: FATAL ERROR: Unhandled e06d7363h Exception at 7c812afbh
12-20-2011 02:20 AM in reply to: best1452
Which folder in the registry is it that needs to be amended with
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R18.0
\ACAD-8000:409\WebServices\CommunicationCenter]
"LastUpdateTimeLoWord"=dword:00000000
"LastUpdateTimeHiWord"=dword:00000000
I'm new to regedit and have suffered from the problems in this thread several times.
I look forward to hearing from you!
Member
Piron88
Message 12 of 18 (6,271 Views)
03-23-2012 09:29 AM in reply to: PMH1985
 i have the same problem with AutoCAD Architecture 2009 when i trying to activate the software license ( the only choice wich i can select, at the first start ) i click activate and appears the fatal error message.
i tried to uninstall with an uninstaller software and install again ACA 2009, but i had the same problem. I tried the solution on this topic, but the registry voices were already correct.
i've installed on my pc ACA 2010, ACA 2012....s.o windows xp sp3 32 bit and active subscription
Someone can help me please ????
Member
HiTree
Message 13 of 18 (5,774 Views)
07-05-2012 04:56 AM in reply to: best1452
Mine had been 0,while fatal error went on。
Member
HiTree
Message 14 of 18 (5,770 Views)
07-05-2012 08:02 AM in reply to: PMH1985
Delete acad.cui,then uninstall the CAD,logout,logon and install the CAD。
I've been succeeded。:catlol:
Active Member
bktx
Message 15 of 18 (4,974 Views)
12-10-2012 07:17 AM in reply to: *Mike Dickason \(Autodesk\)
I'm receiving this error running AutoCAD 2008 on XP Pro. It is occuring each time on startup. I looked through the registry editor to HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R17.1\ACAD-6001:409\WebServices\CommunicationCenter and the values for LastUpdateTimeHiWord and LoWord are both already at 00000000. Sorry if there are already other threads for this issue but any help is greatly appreciated.
Member
HiTree
Message 16 of 18 (4,936 Views)
12-10-2012 06:39 PM in reply to: bktx
You can have a try to follow me,I‘ve post the method upstairs.
I’m Chinese,bless you can get my word!:catwink:
New Member
perslektier
Message 17 of 18 (3,189 Views)
11-14-2013 02:19 AM in reply to: best1452
So, im getting this message: fatal error: unhandled access violation writing 0x0000 exception at 0h, I've tried to change dword: to 00000000 as instruckted still getting the same message.
I've also tryed to download the program (autocad architecture 2014 again) and tryed downloading the 2013 version, all with the same message
New Member
jefferson.morais
Message 18 of 18 (2,780 Views)
Re: FATAL ERROR: Unhandled e06d7363h Exception at 754696c3h
01-17-2014 07:17 AM in reply to: best1452
Re: FATAL ERROR: Unhandled e06d7363h Exception at 754696c3h , perde até desenhos jé realizados .
