AutoCAD Forum
FATAL ERROR Unhandled Access Violation Reading 0xfa6a7488 @ f6b5204eh
1 REPLY 1
3023 Views, 1 Reply
Hoping that someone can help with these far to consistent AutoCAD fatal errors on my work PC. I work in several different versions/years but have the most problems with AutoCAD 2011. I have been working on small edits to a large number of drawings.. So open the sheet, make a few minor changes, save, plot, and move on to the next. I'm getting this same FATAL ERROR every 3-5 sheets and its really waisting a large amount of my time. The errors seem to occur when i'm opening a sheet or closing/saving a sheet. I've been at work for 4 hours so far today and am on error #10. Nobody ever responds to the "send error reports" so I'm looking here for help.
1 REPLY 1
rkmcswain
There is no magic answer. Fatal errors can be caused by a thousand things. The first thing I try and do is determine if this is a drawing problem or a hardware/software problem.
Use RECOVER to open the drawings instead of OPEN. Note any errors fixed.
Try working on the same drawings on a different machine if possible.
Try logging into the machine as a new user if possible, so that you will be starting with a fresh Windows profile and a fresh AutoCAD profile.
Does the error always occur at the same point (like during a save for example)?
Move the drawings from where ever they live now to somewhere else (network drive to a local drive, for example) and test that for a while.
R.K. McSwain     | CADpanacea | on twitter
”Boost
