AutoCAD Forum
FATAL ERROR message opening .dxf file in Auto CAD 2010
2 REPLIES 2
dmays27
1148 Views, 2 Replies
I am having a problem opening a .dxf file in 2010.  After I draw something, I can open it several times but then at random i'll try to open the same drawing and it gives me the error message and closes Auto CAD.  I have attached the .dxf drawing.  Any thoughts on why I get this error and how to fix it and avoid it in the future?  The full error message is:  "FATAL ERROR:  Unhandled Access Violation Reading 0x0004 Exception at 5ef90fa9h"
Tags (1)
2 REPLIES 2
radar696
in reply to: dmays27
I'm not very technical with some things so here is my idea.
Have you tried to do a copy with base point or wblock the contents to a new file to see if the problem is solved that way?
I also would try an erase all command and then do a left to right remove on the visable items.
Just a simple way to remove non-visable items that may be present in the drawing that might be causing your errors.
Just my half-cent ideas!
austin.p
in reply to: radar696
Just had him send me another copy worked great.
Austin Peyser R. S. Mechanical L.L.C
”Boost
