I am having a problem opening a .dxf file in 2010. After I draw something, I can open it several times but then at random i'll try to open the same drawing and it gives me the error message and closes Auto CAD. I have attached the .dxf drawing. Any thoughts on why I get this error and how to fix it and avoid it in the future? The full error message is: "FATAL ERROR: Unhandled Access Violation Reading 0x0004 Exception at 5ef90fa9h"
I'm not very technical with some things so here is my idea.
Have you tried to do a copy with base point or wblock the contents to a new file to see if the problem is solved that way?
I also would try an erase all command and then do a left to right remove on the visable items.
Just a simple way to remove non-visable items that may be present in the drawing that might be causing your errors.
Just my half-cent ideas!
