AutoCAD Forum
Extention line in radial dimension
4 REPLIES 4
Myles1
440 Views, 4 Replies
Is there any way to turn off the annoying extention line that appears when you try to move the text in a radial dimension.  I keep having to turn off ext line in the properties window.  I would like to set the default to off, and turn it on, if I need to.  (I doubt I would ever need to, though)
Autocad 2011
4 REPLIES 4
Alfred.NESWADBA
in reply to: Myles1
open the dimension style dialog, change tab to "Fit" and uncheck the option "Draw dim line between ext lines" ... is that what you are looking for?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Myles1
in reply to: Alfred.NESWADBA
Thanks, but that isn't selected in the dimesnion style.  I have attached an example of what I am talking about.  The first image is what I get when I try to dimension the interior bend.  When I try to pull the text off the part, I get what is shown in the second image, which is not acceptable.  In order to get what I am looking for, image 3, I have to select the dimension, bring up the properties window, and under "Lines & Arrows", turn the Ext Line off.  I have to do this for every radial dimension, for every part, for every drawing.  It is driving me crazy.
Alfred.NESWADBA
in reply to: Myles1
ok, follow these steps:
  • start the dialog for dimension scale
  • select the "NORMAL x3" (from your sample)
  • click "new"
  • in the bottom of the dialog select "Use for:" ==> "Radius dimensions" and then click "Continue"
  • now on tab "Lines" check "Suppress: .... Ext line 1"
  • close all dialogs
HTH, - alfred -
Alfred NESWADBA
Myles1
Excellent, thanks!
”Boost
