AutoCAD 2010/2011/2012
Member
Pixe656
Message 1 of 8 (400 Views)
exporting section-perimeter data-points to text file
400 Views, 7 Replies
10-06-2011 03:41 AM
Hi, I am completely new to the forum and to Autocad. I am using version 2011.
I am working with irregular solids and after I SECTION them, I would like to export to a text file the data points that make up the perimeter of the sections. I have tried googling for a way to do it but couldn't find any helpful information.
Could anyone give me a pointer in the right direction?
Ideally, I would like to do it from the command line, but that's a secondary goal, first of all I would like to know how to do it.
Thank you.
Pixe656
PD: I posted this same message in athoner forum and got no reply at all. Is what I am trying to do even possible?
Possible, if we can see the parts.
Flatshot or use explode the 3d, run thru couple lisps and extract the points.
Patchy
Message 2 of 8 (395 Views)
Re: exporting section-perimeter data-points to text file
10-06-2011 04:44 AM in reply to: Pixe656
Member
Pixe656
Message 3 of 8 (363 Views)
10-07-2011 04:26 AM in reply to: Patchy
Thank you for the information.
I tried Exploding the sections and "nothing" happened (I noticed no difference, I mean). Maybe I have to make a correction to my first post because I didn't mention the objects I am working with (the sections of an irregular solid) are "Region"s. Does that make any difference?
Using flatshot I got the perimeters, all piled on the same plane (OXY), and composed of "line"s. Then, using dataextraction I manaed to create a file with the XYZ coordinates. This is already good enough for me because I am not going to repeat this operation very often, but it's not exactly what I was looking for. Since the flatshot unites all the perimeters onto one plane, in order to have the information of each section independently, I have to flatshot them one by one, and then correct the Z value of each section (which faltshot makes equal to zero).
I am sure all that can be avoided using LISP but I have no experience at all with it, so...
Thank you again for your help.
Pixe
azrdgldr
Message 4 of 8 (355 Views)
10-07-2011 06:18 AM in reply to: Pixe656
Post your ? in the Lisp/Vlisp forum.  You may find what you are looking for there.
Member
Pixe656
Message 5 of 8 (352 Views)
10-07-2011 06:30 AM in reply to: azrdgldr
Thank you for your suggestion.
Just one comment: "Respect is EARNED, and NOT automatically given"
I disagree, one must be respectful to everyone. If you mean I can't just get everything I want from the members of the forum without making any effort, then sure, I agree. If you mean because I am new to the forum I deserve less respect than other members ...
Thank you again,
Julen
Patchy
Message 6 of 8 (344 Views)
10-07-2011 06:47 AM in reply to: Pixe656
That's his Signature, it doesn't mean he has anything against you personally.
Just ignore it.
azrdgldr
Message 7 of 8 (337 Views)
10-07-2011 07:10 AM in reply to: Pixe656
Respect is EARNED!!!!!!!!!!  What you are talking about is common courtesy, treat others as you would like to be treated.  You meet a guy on the streets, is he a child molester, criminal, politician or such?.  You going to respect him.  Not me.  I will treat him with common courtesy as I would treat anyone else.  I reserve my respect for veterans or soldiers who serve(d) to preserve my freedom and liberties.
This is a PHRASE and has no reference or intention to the people who post on these forums.
Member
Pixe656
Message 8 of 8 (333 Views)
10-07-2011 07:26 AM in reply to: azrdgldr
My motherl language is not English and I had the feeling the word "respect" has the meaning you are giving it plus the one I am giving it. Also, I understood your signature as part of your post because I see no difference between the format of the main body and the signature, so I had no way to know it is your signature.
Anyway, thank you for your help and suggestions.
Pixe
