AutoCAD 2010/2011/2012
1Chris2
Message 1 of 29 (11,477 Views)
Export to PDF
11477 Views, 28 Replies
02-15-2011 09:35 PM
I want to export a dwg to pdf. It appears to do it, but doesn't. Keep getting "ERROR: There were no plottable sheets in the current operation."
*Expert Elite*
rkmcswain
Message 2 of 29 (11,422 Views)
Re: Export to PDF
02-16-2011 05:12 AM in reply to: 1Chris2
Are you using AutoCAD 2011?
Are you running the PLOT command or the EXPORTPDF command?
Is your pagesetup set up correctly? (Hint: run the PREVIEW command....what do you get?)
1Chris2
Message 3 of 29 (11,377 Views)
Re: Export to PDF
02-16-2011 12:50 PM in reply to: 1Chris2
I'm running AutoCAD 2011. I absolutely go to Export/PDF; there's no question about that. When I input the preview command, that's what comes up - a preview.
1Chris2
Message 4 of 29 (11,374 Views)
Re: Export to PDF
02-16-2011 12:56 PM in reply to: 1Chris2
I have been using the menus - Export / PDF. The Save as window came up with the PDF extension, but it would not do it. When I typed in the command: exportpdf - it worked.
Thank you for your response.
Any feedback about this?
*Expert Elite*
rkmcswain
Message 5 of 29 (11,362 Views)
Re: Export to PDF
02-16-2011 03:18 PM in reply to: 1Chris2
I don't know what you mean by "...came up with the PDF extension".
The command ._ExportPDF is the built in command that basically takes your current page setup, changes the output device temporarily to PDF, and then creates the file.
1Chris2
Message 6 of 29 (11,318 Views)
Re: Export to PDF
02-17-2011 02:52 PM in reply to: rkmcswain
When I use the menus - Export / PDF, the Save as PDF window comes up. Without modifying anything - even the file name, I click Save and it appears to have worked. Ten seconds later, the error message comes up.
After I read your first reply, I typed EXPORTPDF directly into the command line. It worked...that one time. I tried it subsequently and it does not work. I get the error message using either the menus or the command line.
*Expert Elite*
rkmcswain
Message 7 of 29 (11,308 Views)
Re: Export to PDF
02-17-2011 04:13 PM in reply to: 1Chris2
Unless the menu has been modified, the button you are pressing executes the EXPORTPDF command.
Why it's not working (but worked once) is a mystery to me...
Could it be drawing related? What if you open a new empty drawing, create a few lines, set the page setup properly, then try EXPORTPDF again..?
wesaborgs
Message 8 of 29 (11,164 Views)
Re: Export to PDF
02-23-2011 11:06 PM in reply to: 1Chris2
I have the exact same problem.
I want to export a drawing to PDF, using Acad Mechanical 2011. It's an ordinary drawing with borders and title blocks. (A2 format.)
When I open a new drawing (without any borders or such) and export it, there's no problem. So it seems to be related to the drawing itself. But I have no idea what to do about it.
I've had this problem from time to time, but only with some drawings.
Would be nice if someone knows how to fix it   ;-)
EDIT: I typed PLOT in the Command field, and then the problem was solved.
Valued Mentor
TrevN
Message 9 of 29 (11,155 Views)
Re: Export to PDF
02-24-2011 01:50 AM in reply to: wesaborgs
Maybe a stupid question!!
But why would you want to Export to PDF when PLOT works every time?
wesaborgs
Message 10 of 29 (11,153 Views)
Re: Export to PDF
02-24-2011 02:00 AM in reply to: 1Chris2
In my case, I use Inventor and have never really learned how to do stuff in Acad. In inventor the way to do it is from the menu and Export to dwf or pdf etc.
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
