AutoCAD 2010/2011/2012
Active Member
oleckliter
Message 1 of 8 (833 Views)
Accepted Solution
Export as PDF fails in ACAD 2012 Student Edition
833 Views, 7 Replies
04-29-2012 10:22 AM
I have repeatedly attempted to export a simple drawing as a PDF and it doesn't take.  I get an error message that the plot failed because there is nothing to plot (paraphrased).
Does export as a PDF not work or not in the Student version or?
Bingo!
Thanks.
*Expert Elite*
Alfred.NESWADBA
Message 2 of 8 (832 Views)
Re: Export as PDF fails in ACAD 2012 Student Edition
04-29-2012 10:48 AM in reply to: oleckliter
what does the preview look like? If it's also empty it seems to be a wrong defined plot-area or plot-scale or plot-papersize.
Check all that in the PLOT-dialog.
Without seeing and knowing what you are exactly doing, it's difficult to help. What are you doing the get that issure? Have you started plot from modelspace or plot from layout or the export-command?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
Active Member
oleckliter
Message 3 of 8 (831 Views)
04-29-2012 11:16 AM in reply to: Alfred.NESWADBA
alfred:
1.  There is no "preview" available, I am trying to Export as a PDF, not do a plot.  My comment re the plot was because the error message is presented as a "plot" error.
2.  As a test I have just been using a simple rectangle.
See the two attachments.
Thanks.
*Expert Elite*
Alfred.NESWADBA
Message 4 of 8 (827 Views)
04-29-2012 11:36 AM in reply to: oleckliter
Then try to use command _PLOT, there you have a preview and more control over what to be exported.
BTW: you have installed the latest servicepack (from >>>here<<<)?
- alfred -
Alfred NESWADBA
Active Member
oleckliter
Message 5 of 8 (825 Views)
04-29-2012 11:55 AM in reply to: Alfred.NESWADBA
alfred:
The normal plot dialog works fine (displays the rectangle just fine in preview).  However, I find no way to generate a PDF using that approach.  Again, I'm trying to get a PDF file - which the "Export as PDF" approach appears to be the only game in town.  Now, how do I get it to work?  Or is there another way to get a PDF of the dwg image?
Active Member
oleckliter
Message 6 of 8 (822 Views)
04-29-2012 12:04 PM in reply to: oleckliter
alfred:
BTW - yes, I installed the service pack long ago.
*Expert Elite*
Alfred.NESWADBA
Message 7 of 8 (820 Views)
04-29-2012 12:08 PM in reply to: oleckliter
Within the plotter-dialog you have a list of printers, chose "DWG to PDF.pc3" as your destination plotter. Then you get a PDF created.
- alfred -
Alfred NESWADBA
Active Member
oleckliter
Message 8 of 8 (818 Views)
04-29-2012 12:16 PM in reply to: Alfred.NESWADBA
Bingo!
Thanks.
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
