AutoCAD 2010/2011/2012
Active Member
oleckliter
Message 1 of 8 (796 Views)
Export as PDF fails in ACAD 2012 Student Edition
796 Views, 7 Replies
04-29-2012 10:22 AM
I have repeatedly attempted to export a simple drawing as a PDF and it doesn't take.  I get an error message that the plot failed because there is nothing to plot (paraphrased).
Does export as a PDF not work or not in the Student version or?
Bingo!
Thanks.
Alfred.NESWADBA
Message 2 of 8 (795 Views)
Re: Export as PDF fails in ACAD 2012 Student Edition
04-29-2012 10:48 AM in reply to: oleckliter
what does the preview look like? If it's also empty it seems to be a wrong defined plot-area or plot-scale or plot-papersize.
Check all that in the PLOT-dialog.
Without seeing and knowing what you are exactly doing, it's difficult to help. What are you doing the get that issure? Have you started plot from modelspace or plot from layout or the export-command?
- alfred -
Alfred NESWADBA
Active Member
oleckliter
Message 3 of 8 (794 Views)
04-29-2012 11:16 AM in reply to: Alfred.NESWADBA
alfred:
1.  There is no "preview" available, I am trying to Export as a PDF, not do a plot.  My comment re the plot was because the error message is presented as a "plot" error.
2.  As a test I have just been using a simple rectangle.
See the two attachments.
Thanks.
Alfred.NESWADBA
Message 4 of 8 (790 Views)
04-29-2012 11:36 AM in reply to: oleckliter
Then try to use command _PLOT, there you have a preview and more control over what to be exported.
BTW: you have installed the latest servicepack (from >>>here<<<)?
- alfred -
Alfred NESWADBA
Active Member
oleckliter
Message 5 of 8 (788 Views)
04-29-2012 11:55 AM in reply to: Alfred.NESWADBA
alfred:
The normal plot dialog works fine (displays the rectangle just fine in preview).  However, I find no way to generate a PDF using that approach.  Again, I'm trying to get a PDF file - which the "Export as PDF" approach appears to be the only game in town.  Now, how do I get it to work?  Or is there another way to get a PDF of the dwg image?
Active Member
oleckliter
Message 6 of 8 (785 Views)
04-29-2012 12:04 PM in reply to: oleckliter
alfred:
BTW - yes, I installed the service pack long ago.
Alfred.NESWADBA
Message 7 of 8 (783 Views)
04-29-2012 12:08 PM in reply to: oleckliter
Within the plotter-dialog you have a list of printers, chose "DWG to PDF.pc3" as your destination plotter. Then you get a PDF created.
- alfred -
Alfred NESWADBA
Active Member
oleckliter
Message 8 of 8 (781 Views)
04-29-2012 12:16 PM in reply to: Alfred.NESWADBA
Bingo!
Thanks.
