Hi!
I need to create a rather simple function (I thought) but I haven't found anything really useful on the internet.
We have a excel document that we uses for project management (mechanical and electrical drawings).
Based on the data in the excel file I need to make some text changes in the dwg files.
Right now we are doing it manually via the find m (search / replace) but it´s to time ineffective.
So what I need to do from excel.
1. Enter the search and replace values (let´s say column A and B)
2. Press my Go button
3. A dwg is opend (my template)
4. Get all objects and find texts and attributes that fits the search
5. Replace them with the text from excel
I know how to open the dwg but I have no idea how to perform the search and replace.
Option Explicit Sub FindReplace() 'Declaring the necessary variables. Dim acadApp As Object Dim acadDoc As Object Dim searchString As String Dim replaceString As String searchString = "xRefObjectNumber" replaceString = "M200" 'Check if AutoCAD application is open. If is not opened create a new instance and make it visible. On Error Resume Next Set acadApp = GetObject(, "AutoCAD.Application") If acadApp Is Nothing Then Set acadApp = CreateObject("AutoCAD.Application") acadApp.Visible = True End If 'Check (again) if there is an AutoCAD object. If acadApp Is Nothing Then MsgBox "Sorry, it was impossible to start AutoCAD!", vbCritical, "AutoCAD Error" Exit Sub End If On Error GoTo 0 'If there is no active drawing create a new one. On Error Resume Next Set acadDoc = acadApp.ActiveDocument If acadDoc Is Nothing Then Set acadDoc = acadApp.Documents.Add End If On Error GoTo 0 ' Now What????!!! :) 'Release the objects. Set acadDoc = Nothing Set acadApp = Nothing End Sub
Please help me.
Best Regards
>> Now What????!!! 🙂
Scan through all blockdefinitions in the blocktable ( acaddoc.Blocks )
Within each blockdefinition (that is no reference object like XRef) scan through all elements and see if it's a text, a mtext, a dimension or a blockreference containing attributes ... and if it's such an objects search for the textcontent and see if there is anything to change.
At least one additional info: there is a special forum for VBA >>>there<<< (for your next questions if you have any) 😉
Good luck, - alfred -
