AutoCAD 2010/2011/2012
Active Contributor
beh160
Message 1 of 5 (789 Views)
Excel spreadsheets show up with gridlines
789 Views, 4 Replies
12-12-2012 08:44 AM
I have been having an  issue when printing to PDF from AutoCAD my Excel spreadsheets show up with gridlines that are not there in there Excel or CAD. I have tried a number of things to eliminate that lines (see list below) but nothing has worked so far. I am running AutoCAD 2012 and Excel 2003. I have inserted the spreadsheet using "Paste Special" so that I can continue to work on the spreadsheet in excel and it will update in CAD.
-  I have changes the Plot Quality. In Monochrome the lines print. Low quality the spreadsheet does not show up. High quality again nothing shows up
- In Excel I have turned off the "Gridlines" and re-copied into AutoCAD. The lines still show up when printing to PDF
- If I paste as an AutoCAD Entity I can not update in Excel
Please let me know if you have any other ideas. I would really like to get this to work.
Valued Contributor
nannerdw
Message 2 of 5 (786 Views)
Re: Excel spreadsheets show up with gridlines
12-12-2012 09:08 AM in reply to: beh160
I had this issue in the past, and ended up setting the fill color in Excel to white instead of "No FIll."
-Using Autodesk Inventor Professional 2012
Active Contributor
beh160
Message 3 of 5 (778 Views)
12-12-2012 10:50 AM in reply to: nannerdw
Unfortunately I just tried making the fill white and the lines are still showing up.
sbennett
Message 4 of 5 (755 Views)
12-14-2012 01:25 PM in reply to: beh160
Ok, I brought into autocad "paste special" as an excel file, with grid lines off. It pasted without lines and plotted without lines!
sbennett
Message 5 of 5 (754 Views)
12-14-2012 01:28 PM in reply to: sbennett
sorry I was in a hurry... I copied the excel info, went to ACAD and selected 'paste special' then 'Paste Link', then used 'Microsoft Excel Worksheet' and it printed clean
