AutoCAD 2010/2011/2012
Valued Contributor
MatthewB80097
Message 1 of 4 (202 Views)
Excel file attachment stuck
202 Views, 3 Replies
11-29-2012 07:32 AM
We have this problem at the moment with an microsoft excel file that appears to have become stuck in the External references list, Ref C1-01-06. We would like to remove it if possible as it is now superseded (we can't change the file name unfortunatly. What do we do if we can't reload, detach or bind? Its not referenced into anything else that is attached to the file, it is a direct attachment of the file that we are in.
*Pro
ampster
Message 2 of 4 (191 Views)
Re: Excel file attachment stuck
11-29-2012 08:13 AM in reply to: MatthewB80097
have you tried the audit command to fix any errors with this file?
Valued Contributor
MatthewB80097
Message 3 of 4 (187 Views)
11-29-2012 08:17 AM in reply to: ampster
Sorry to reliterate its the link that's stuck not the file itself. Tried audit and that didn't find anything wrong.  Also we tried adding the 'found at' file path thinking that could be the problem but that doesn't sort it either.
*Pro
ampster
Message 4 of 4 (177 Views)
11-29-2012 08:54 AM in reply to: MatthewB80097
sometimes audit will find errors that can affect anything within a file, links included.
What about the purge command?  You mentioned the excel file isn't used anymore, maybe a purge can get rid of it (probably not but worth a try)
