AutoCAD 2010/2011/2012
Member
jtuulse
Message 1 of 6 (232 Views)
Everything is completely black!
232 Views, 5 Replies
10-04-2012 07:10 AM
I'm new to using AutoCAD, so please bear with me if this is super clear to everyone else...
I have been working on a drawing, and all of a sudden everything turns completely black. That is, model space and layout space is all black. Menus and tool sets and layers box and such are still visible, I seem to be able to draw things and select things, but I can't see my drawing. It's just all black. It's the same if I open a new drawing too. All black.
I have been working with xref images, if that might be a pard of the problem?
Accidentally I pressed cmd + . and then I could see my layouts, and my drawing is there and everything. But the model space is black. And no grid either.
Did I accidentally press a button or activate a command that I don't know about? I could redo everything, it's nothing super importan, only the same thing happens if I open a new document.
Any help is appreciated!
/Johanna
Patchy
Message 2 of 6 (225 Views)
Re: Everything is completely black!
10-04-2012 07:21 AM in reply to: jtuulse
If you attach your drawing here, it'll help to find out why.
Member
jtuulse
Message 3 of 6 (216 Views)
10-04-2012 08:18 AM in reply to: Patchy
Oh, I didn't even know I could do that! Brilliant! Here it is, and thank you!
Patchy
Message 4 of 6 (212 Views)
10-04-2012 08:37 AM in reply to: jtuulse
Your drawing without the images works fine, the photos might have used up all the memories.
Unload 1 photo or both and see if it'll help.
Member
jtuulse
Message 5 of 6 (198 Views)
10-04-2012 11:21 AM in reply to: Patchy
Thanks! I'll try that and see if it helps. The wierd thing is that even if I open a new empty document it's all black. But I'll try and see if that dies the trick.
If it IS the image, would it help if I tried to make it smaller?
I'll post again once I've figured out if this helps. Thanks again.
Member
jtuulse
Message 6 of 6 (188 Views)
10-04-2012 11:33 AM in reply to: jtuulse
And now suddenly it works just fine, I didn't even remove the image. Seriously I don't know what I'm doing more than half the time.... Anyway, still have lots to learn apparantly, and thanks a bunch for taking the time to try and help me!!
Also, it's good to know that the image might be causing some troubles, that will be the first thing I try and remove if I have further problems!
Thx again!
