AutoCAD 2010/2011/2012
Active Contributor
M_Mogharabi
Message 1 of 5 (332 Views)
Error : typeInitializationException
332 Views, 4 Replies
01-06-2012 09:05 PM
Hi all,
I've found a code to open a dwg file in autocad with objectARX commands.this code works successfully when i wrote it in a Class Library project, but the problem is happened when i want to place this code in my windows application.It gives me this error message :
The type initializer for '< Module >' threw an exception.
Inner Exception : The C++ module failed to load during process initialization.
My code is :
String MyDWGFilePath = @"\\Server\SharedFolder\Projects\File1.dwg";
DocumentCollection dm = Application.DocumentManager;
Document doc = null;
if(File.Exists(MyDWGFilePath))
   doc = dm.Open(MyDWGFilePath, false);
   Application.DocumentManager.MdiActiveDocument = doc;
 Note: I've add acdbmgd.dll and acmgd.dll from autocad installed folder and also AutoCAD and AXDBLib from COM references.
please tell me what is my mistake???
Alfred.NESWADBA
Message 2 of 5 (329 Views)
Re: Error : typeInitializationException
01-06-2012 11:49 PM in reply to: M_Mogharabi
Do you mean that you develop an external EXE (and not an internal DLL)? If so you have no access to the managed API (it's near to ObjectARX, but it's not ARX). The only option then is to work with COM.
- alfred -
Alfred NESWADBA
Active Contributor
M_Mogharabi
Message 3 of 5 (328 Views)
01-07-2012 12:40 AM in reply to: Alfred.NESWADBA
Hi alfred,
Do you mean ObjectARX just works in DLLs but not in exe applications?
So how can i open a dwg file from a windows application?
please describe for me how can i use COM instead of ARX?
i'm too confused.please help me...
Alfred.NESWADBA
Message 4 of 5 (325 Views)
01-07-2012 12:57 AM in reply to: M_Mogharabi
ObjectARX works only within AutoCAD, plus ObjectARX is written in C++ so it's unmanged and it's not a DLL, it's a special kind of DLL with the extension ARX
If you do your coding with C# or VB.NET (or any dotNET based language) then you are using the managed API from AutoCAD and also this (DLL then) runs only inside of AutoCAD (either loaded with command _NETLOAD or some settings in the registry to get loaded autmatically).
If you control AutoCAD from an external EXE you can only use the COM/ActiveX way and that works in the same way as you control Excel, Word or any other COM-based API.
You can start it with
CreateObject("AutoCAD.Application")    'or also using the version-number if you have to start a specific release
or you can use the Processes to start another EXE like:
Processes.Start("ACAD.EXE")   'of course you will use the path to the exe here
and then GetObject(,"AutoCAD.Application")    'to get access to the AutoCAD ActiveX server
A lot of search samples could be found using Google with >>>CreateObject("AutoCAD.Application")<<<
HTH, - alfred -
Alfred NESWADBA
Active Contributor
M_Mogharabi
Message 5 of 5 (311 Views)
01-08-2012 09:09 PM in reply to: Alfred.NESWADBA
ahaa, now i can understand it clearly.
Thanks alot .........
