Is there a way to edit attributes of multileader _tagcircle with a script. There is no line equivalent of ddedit that I know of. -Attedit does not work. Thanks
I would not want to write the code for it, but if you start with (setq en (entsel))
then apply (setq ent (entget (car en)))
then way down at the end of the result of that you will see a dxf code 302 with the attribute data in it.
Getting to that and substituing your desired value would be an odyssey!
