AutoCAD 2010/2011/2012
Valued Contributor
jamesbarnett
Message 1 of 6 (857 Views)
Accepted Solution
Dynamic title blocks
857 Views, 5 Replies
02-04-2013 12:09 PM
I need to create a dynamic title block, so I can change the date on layout 1 and all the others change too. Can someone point me in the right direction to learn how to do this?
AutoCAD Civil 3D 2014 SP 1
Windows 7 (64)
In the title block insert a field, in the Field dialog set the Field Category on Document and you should see your custom properties.
When you have your drawing template file the way you want you can use the command Propulate to export a custom properties template and import it into an existing drawing. Propulate is not the most straightforward command so have some patience and pay attention to the command line.
Valued Mentor
tim.turner
Message 2 of 6 (848 Views)
Re: Dynamic title blocks
02-04-2013 01:09 PM in reply to: jamesbarnett
Add your date to the Custom tab of Drawing Properties(dwgprops). Put a field in the title block to retrieve this value.
Valued Contributor
jamesbarnett
Message 3 of 6 (831 Views)
02-05-2013 05:08 AM in reply to: tim.turner
How do I retrieve the value?
Windows 7 (64)
Valued Mentor
tim.turner
Message 4 of 6 (825 Views)
02-05-2013 05:19 AM in reply to: jamesbarnett
doben
Message 5 of 6 (825 Views)
02-05-2013 05:20 AM in reply to: jamesbarnett
I would use a sheet set.
Valued Contributor
jamesbarnett
Message 6 of 6 (821 Views)
02-05-2013 05:24 AM in reply to: tim.turner
Thanks for the help.
Windows 7 (64)
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
