Attached is a dynamic title block with various width which I created based on the you tube video. The problems that I have with the video is the following:
Title block problems
Any help would be appreciated.
http://www.youtube.com/watch?v=TyM3u88KJpI
The text attributes don't work because they are not attributes, they are plain text.
To add attributes, use the ATTDEF command
To align the attributes, use the MOVE command, or TEXTALIGN command
To have the graphic it inside the box, use the scale command
To be able to edit this as a block you need to define it as a block first.
To be able to modify the x and y directions you will need to add dynamic action to the block definition.
And do not use hatches to draw borders and lins in your title block, use polylines as suggested in previous response.
