I need help on a dynamic block.
I like to make a frame for pallet racks.by using dynamic block.
I can make it wider and higher, but the problem is to get the "bracing" (zig zag pattern).
Any good tips?
Solved by ojuris. Go to Solution.
Close.
The last arrey comes a bit late... i get a beit to much "overhang" on the upright before the bracing comes.
My goal is this solution (with the bracing).
But i cant manage the bracing...
the bracing has only one type (length) in height cc-600mm
I need it to fill all the way to the top of the frame.
We have some special solution to the bracing at the top on some heights, but for the time, it is ok to only have the cross bracings in the block.
Im still missing the top bracing.
Try to make a frame that is 2000mm high.
this will give you 2 x-bracings, in reality it is room for 3.
is it what you looking for?
if you need bracings for higher frame - you must add additionla linet lo lookup tables
in block you'll see 2 lookup tables
in table Lookup1 for parameter Høyde each next row must have numbers by 600mm bigger than previous row
in table Lookup2 for parameter HBr each row must be bigger by 600mm, but rows Ar1 and Ar2 each second row must be bigger by 1200 -> follow existing order for that columns
right side row (Lookup Properties) in both tables must be equal.
Regards
Juris
thx.
Looks good.
When i try to replicate your solution, i cant get the top bracing to fit (at 2000mm)...
But this will do good for now.
