AutoCAD Forum
dynamic block
11 REPLIES 11
Message 1 of 12
582 Views, 11 Replies
dynamic block
I need help on a dynamic block.
I like to make a frame for pallet racks.by using dynamic block.
I can make it wider and higher, but the problem is to get the "bracing" (zig zag pattern)SD.JPG.
Any good tips?
11 REPLIES 11
Message 2 of 12
ojuris
Message 3 of 12
in reply to: ojuris
Close.
The last arrey comes a bit late... i get a beit to much "overhang" on the upright before the bracing comes.
Message 4 of 12
ojuris
may be that is better
Message 5 of 12
in reply to: ojuris
My goal is this solution (with the bracing).
But i cant manage the bracing...
the bracing has only one type (length) in height cc-600mm
I need it to fill all the way to the top of the frame.
We have some special solution to the bracing at the top on some heights, but for the time, it is ok to only have the cross bracings in the block.
Message 6 of 12
ojuris
Message 7 of 12
in reply to: ojuris
Im still missing the top bracing.
Try to make a frame that is 2000mm high.
this will give you 2 x-bracings, in reality it is room for 3.
Message 8 of 12
ojuris
is it what you looking for?
if you need bracings for higher frame - you must add additionla linet lo lookup tables
Message 9 of 12
in reply to: ojuris
This is what i'm looking for.
But im not sure i understand how to add lines.
I need this to go to 10.000mm
Message 10 of 12
ojuris
in block you'll see 2 lookup tables
in table Lookup1 for parameter Høyde each next row must have numbers by 600mm bigger than previous row
in table Lookup2 for parameter HBr each row must be bigger by 600mm, but rows Ar1 and Ar2 each second row must be bigger by 1200 -> follow existing order for that columns
right side row (Lookup Properties) in both tables must be equal.
Regards
Juris
Message 11 of 12
ojuris
Message 12 of 12
in reply to: ojuris
thx.
Looks good.
When i try to replicate your solution, i cant get the top bracing to fit (at 2000mm)...
But this will do good for now.
”Boost
