Hello All,
I want to know if it’s possible in autocad 2012 WITHOUT USING LISP to fix the next problem
by a certain width I have several options of length,
for example
for a width of 13 inch I have 29 possible lengths
The width has on its own 29 options
when Ii select for example 13" wide, I want to be able to have a next option what shows me the possible lengths
when I want to do this in a visible state I have 29 to the 16the power options. It will be a little less because when the wide will increase the amount of length options will decrease but still it will be too much.
I'm relitive new with dynamic blocks, i don't know if i can use a table for this.
Does anyone have a possible solution for this challenge
If you have can you give me an example how i can tackle this challenge
Kind regards
Marc
I'm not to sure if this will work. Use a visiblity state for each of the widths, and then use a lookup table for each of the lengths.
Posting here as well Dynamic Block Forums will also help.
Howard Walker
