AutoCAD 2010/2011/2012
New Member
teyichee
Message 1 of 2 (389 Views)
Dynamic area
389 Views, 1 Replies
10-31-2012 07:28 AM
I have a question concerning area command. I would like to connect polyline (floor area) and text in it in which I could see the area in square meters. And also that that text changes if I change the polyline.
When I have that I would need a table with floor areas, in which also numbers change if I change the floor area polyline.
Thank you in advance,
Tea
*Expert Elite*
pendean
Message 2 of 2 (387 Views)
Re: Dynamic area
10-31-2012 07:58 AM in reply to: teyichee
1. FIELD command, OBJECT field name on the list, click on the OBJECT TYPE button, select the Pline, choose the property you want (AREA in this case), edit the format and help yourself. REGEN to update a field when a Pline changes.
2. Same as above, except in a table if you want to use a TABLE object type in AutoCAD or just a bunch of lines that look like a table.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
