I would like to know that When I save file in DXF format, It is giving 30,31,32 Group codes also.
I am confused as there will be only 2D entities in DXF file, why group code regarding Z co-ordinate is available in DXF file?
Thanks in Advance...
Ketan Lalcheta
Please correct me if I am wrong.
AutoDesk supports only 2D DXFs as we are not able to save Any Parts (3D) as DXF from CATIA or even from Inventor.
Only drawings (2D) can be saved in DXF and hence it is confusing why it is required to have Z co-ordinate.
Thanks for concern on this topic.
I intended to create DXF file for Inventor part but not able to create. Then I generated drawing and exported to DXF format. While analysing the DXF file, There was provision for Z co-ordinate. So, I am confused that what is usefullness of Z co-ordinate in 2D DXF file?
In addition to that, I would like to know that does AutoDesk provide DXF for 3D entities?
Hope I have cleared your doubt.
Ketan
Here is a 3d object that I created and exported to DXF, then I opened the DXF in DWG Trueview.
I guess 7 years too late 😉
- alfred -
