AutoCAD Forum
dwgprops from xref
7 REPLIES 7
Message 1 of 8
knoetzl
664 Views, 7 Replies
dwgprops from xref
I have question dedicated to dwgprops of dwgs which are attached (overlayed) as xref in "current drawing". What is the problem: In our drawings we use dwgprops (custom prop) as ground elevation (for example in custom prop. we use (name)GE (value)+6.16). And this value is feeded direct to model as field. Problem begings when this dwg is attached as xref in other drawing. There you can see only #### or value (must have same name GE) wich is filled in current drawing. Is there any way to force xref to use its dwgprops?
Jozef
7 REPLIES 7
Message 2 of 8
JoAnn_Hogan
in reply to: knoetzl
Sorry I am trying to understand. Is the problem that you cannot see the 1st xref in the next drawing? If that is the case, change your attachment type to attachment and not overlay. If it is still an issue, could you send me the dwgprops so I could have a look at it?
If this post solved your issue please mark as solved and Kudos are always welcome 😃
Jo - Ann
Twitter: @JoAnn_Hogan
Revit Architecture Certified Professional / Revit Structure Certified Professional / AutoCAD Certified Professional
Message 3 of 8
knoetzl
in reply to: JoAnn_Hogan
Here is the sample what i need. Everything is explained inside drawing3.dwg. drawing1 and drawing2 are xrefs for drawing3
Thax for quick response
Message 4 of 8
pendean
So you are trying to access the DWGPROPS entries of XREFed files in your top file?
Message 5 of 8
knoetzl
in reply to: pendean
That is what i am looking for. Reason is very simple. Same custom name have in each level (drawing) different value. So when i copy entities with same custom name it gives me exact value what i am looking for.
Message 6 of 8
pendean
Simple if you have this add-on (if I understood your need correctly):
http://www.dotsoft.com/tp13new.htm
The folks in the customization forum might be able to help you write a routine to extract this info while you wait here for others to dive in:
Customization Discussion area http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/bd-p/130
Message 7 of 8
knoetzl
I was looking for solution and have some find out. When i set fieldeval to 0 in xrefed drawings. In current drawing i can see atributtes as i need. Only problem is to changing fieldeval from 31 to 0 and than back to 31 is annoying
Message 8 of 8
knoetzl
Now it´s solved. Just set fieldeval to 30
”Boost
