AutoCAD 2010/2011/2012
Valued Contributor
jbalaneski
Message 11 of 13 (821 Views)
Re: DWG to PDF - "Flattening" during printing and Black Boxes on Text
02-21-2012 11:43 AM in reply to: pendean
I was able to find a brand spanking new machine with a fresh install of C3D/AutoCAD 2011 on it.  Never been used or tweaked in anyway.  I found the DWG to PDF.pc3 default file and copied it on to my system.  And then applied the necessary changes to the file to avoid the flattening issue...and low and behold the black boxes disappeared on the output PDF file.  I think maybe my pc3 file, even though it was the original, some how got corrupted.
Thanks for all your help guys!
pendean
Message 12 of 13 (817 Views)
02-21-2012 12:00 PM in reply to: jbalaneski
Thanks for the follow-up: please check your own answer as an accepted solution so that others can find it easily.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Distinguished Contributor
ssx_Autodesk
Message 13 of 13 (806 Views)
02-21-2012 04:53 PM in reply to: pendean
an alternative that i've found to be quite stable is to install PDF Creator (open source, but be careful of installing the toolsbars they bundle with it) and set that printer to auto-save to a particular folder (i have a C:\PDFs folder and a shortcut on my desktop)
then i create a specific pagesetup for that printer.
it's been rock solid and also free.
(my biased opinion is that Adobe has gotten too fancy over the years - Acrobat has some nice features, but it's much more complex than i need it to be)
______________________________
~ "if this were /. this would be funny"
