Recently it was suggested that we should use The built in pdf maker "dwg to pdf.pc3" to avoid black boxes being printed from wipeouts.
That works great.
However when I created pdf's for several sheets, One of them (see attached) created black boxs from the mtext mask which was on and matched background but the wipeouts where ok.
And the strange thing is it didn't do that on all sheets. Is it the mtext setup on that sheet that cause the problem?
Thanks in advance for your support
John Wilson
Before we getting the final solution, please try the method provided in the link below.
You can also upload the original drawing so we can investigate further.
I viewed some annotation are plotted correctly. Could you modify the plotter properties, in Font Handling, check "capture all"?
If issue still exist, could you send us dwg file to research?
Hello
Just a quick idea ...
If you are using MTexts with blank/white masks, have you used the REAL White which is RGB = 255,255,255 ?
and NOT the color code = 7 (Black/White)
Patrice BRAUD
