AutoCAD Forum
DWG to PDF mtext mask black boxes
5 REPLIES 5
johnwilson0805
726 Views, 5 Replies
Recently it was suggested that we should use The built in pdf maker "dwg to pdf.pc3" to avoid black boxes being printed from wipeouts.
That works great.
However when I created pdf's for several sheets, One of them (see attached) created black boxs from the mtext mask which was on and matched background but the wipeouts where ok.
And the strange thing is it didn't do that on all sheets. Is it the mtext setup on that sheet that cause the problem?
Thanks in advance for your support
John Wilson
5 REPLIES 5
3wood
in reply to: johnwilson0805
Before we getting the final solution, please try the method provided in the link below.
You can also upload the original drawing so we can investigate further.
Yong.Jing
I viewed some annotation are plotted correctly. Could you modify the plotter properties, in Font Handling, check "capture all"?
If issue still exist, could you send us dwg file to research?
Yong Jing
Product Support Senior Specialist
Technical Support, CSS, GPS
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
如果我的回帖解决了您的问题,请点击 "接受为解决方案" 按钮. 这可以帮助其他人更快的找到解决方案!
braudpat
Hello
Just a quick idea ...
If you are using MTexts with blank/white masks, have you used the REAL White which is RGB = 255,255,255 ?
and NOT the color code = 7 (Black/White)
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
johnwilson0805
in reply to: braudpat
I tried that but it didn't work.
Thanks it was worth a try
Sent from my iPhone
johnwilson0805
in reply to: Yong.Jing
I tried the "capture all" but it still didn't work. Here is the drawing as you requested.
Thanks a lot for your interest in my problem.
John Wilson
”Boost
