Hello, I am trying to create a quality image from a DWG drawing. I have tried using "Publish to the Web - JPG" but I am not having great results. Not really clear. I have also tried JPGOUT at the command prompt with poor results. There must be a better way to do this?
Thanks in advance
Kev
Solved by Ajilal.Vijayan. Go to Solution.
A couple of things -- plot to PDF or EPS, and convert the resulting file to TIFF or PNG
Or look at BetterWMF as a 3rd party solution
JPG is pretty bad for linework, marginal for images. PNG is better for both, although as noted by JGerth you need to take a couple of extra steps. Depending on what you are looking to do, there may be better options than an image file.
