AutoCAD 2010/2011/2012
richardfreeman
Message 1 of 6 (10,938 Views)
dwg to jpeg convert
10938 Views, 5 Replies
04-10-2011 01:30 PM
how using autocad do you convert a dwg file to jpeg so you can send it to another person to view that does not have autocad
Ric
*Expert Elite*
Murph
Message 2 of 6 (10,923 Views)
Re: dwg to jpeg convert
04-10-2011 04:58 PM in reply to: richardfreeman
Use the jpgout command.
Set up a jgp PC3 file that uses a raster format with the plotter wizard.
Alternative methods to provide your dwg to another that does not have AutoCAD is plot to dwfx format to view in windows vista os, plot to dwf and point the non-autocad user to the free design review software, last is plot to pdf and let them open it in any pfd reader.
Murph
Supportting the troops daily.
*Pro
ampster
Message 3 of 6 (10,874 Views)
04-11-2011 08:34 AM in reply to: richardfreeman
What about the "Print Scrn" key on the keyboard...although it takes some extra work to use it.
neaton
Message 4 of 6 (10,870 Views)
04-11-2011 08:43 AM in reply to: richardfreeman
Autodesk Lab's Screenshot may do the trick, too. http://labs.autodesk.com/utilities/screenshot/. Added benefit of Screenshot is turning the black background a lot of use to white for the the print.
Nancy
*Expert Elite*
AllenJessup
Message 5 of 6 (10,860 Views)
04-11-2011 10:13 AM in reply to: richardfreeman
Or, depending on how much you want them to see, have them install DWG TrueView and send them the whole drawing.http://usa.autodesk.com/adsk/servlet/pc/index?siteID=123112&id=6703438&DCMP=ILC-DWG-PUV
Plotting to PDF is also and option. It's a good one if you want to produce multiple sheets from layouts. Just select all the layouts, rt-click and select Publish. You'll have to set up a Page Setup using a PDF plotter first. Then you can set that as the Plotter to use for each sheet.
Allen
Distinguished Contributor
mmcmanus
Message 6 of 6 (10,854 Views)
04-11-2011 10:37 AM in reply to: richardfreeman
If it has to be a JPG file, then plot to PDF so you can control all the features as needed and then just do a "save as" from Adobe to a JPG file.
Post to the Community
New Post
Need installation help?
