AutoCAD 2010/2011/2012
Active Contributor
thebeesnees
Message 1 of 5 (675 Views)
Accepted Solution
Duplicate Attribute (echo)
675 Views, 4 Replies
11-16-2012 02:25 AM
I have a drawing template (block) where the drawing number is displayed in two locations (attributes). The same value has to be entered in both attributes.
Is there any way of "echoing" the data from one attribute to other attributes (or text objects)?
Almost perfect.
Only minor issue is that the second attribute (COPY) can be overwritten accidentally. Would be ideal if the second attribute could be hidden or protected although I don't think it is possible.
Does the job though, thanks for your help.
*Expert Elite*
Alfred.NESWADBA
Message 2 of 5 (666 Views)
Re: Duplicate Attribute (echo)
11-16-2012 05:21 AM in reply to: thebeesnees
using fields can do that (>>>details<<<).
Check the attached drawing with one sample block inserted. Change it's attribute "ORIG" and after that do a _REGEN.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
Active Contributor
thebeesnees
Message 3 of 5 (660 Views)
11-16-2012 06:08 AM in reply to: Alfred.NESWADBA
Almost perfect.
Active Contributor
cvc-it-mb
Message 4 of 5 (300 Views)
02-13-2014 11:53 AM in reply to: Alfred.NESWADBA
Ok, nice example. But how did you do it?
Active Contributor
cvc-it-mb
Message 5 of 5 (293 Views)
02-13-2014 03:17 PM in reply to: cvc-it-mb
Found it... I was unclear on the step-by-step.
  1. Create a single attribute.
  2. Create an MText object or another Attribute.
  3. Within the editor, open the shortcut menu (right-click in edit-box) and select insert field.
  4. Field Category: Objects
  5. Field Names: Object.
  6. For Object Type, click the select object button, then select the attribute from your drawing.
  7. Select Property: Value.
Jim
Announcements
Need installation help?
