as the title imposes i'd like to have my Drawing units set to mm and the unit for Area set to m².
However, when setting it up in the Drawing Setup, it still gives me all calculated areas (via Properties or Measure tool) in mm².
Anyone knows how to get it right?
Solved by GrantsPirate. Go to Solution.
thanks fo your answer.
unfortunately this doesn't do the trick, as there is no opion for areas (and besides that it pretty much does the same as _AECDWGSETUP - doesn' it?)
kind regards
GrantsPirate
Piping and Mech. Designer
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Arr, thats a nice work around!
as you said, not exactly whar i was looking for but it does the trick. Thanks
