I'm having an issue with some of my drawings where the all the lineweights appear much too thick on the screen. When I plot the drawing or look at a print preview the lineweights appear correct, but in model space they appear much too thick.
I found the option to show / hide lineweights, and when I toggle this option from show to hide it seemingly fixes the issue, but when I pan or zoom on the drawing the think lineweights come back.
I have no idea why this is happening, even with show lineweights enabled they should not be displaying this thick as every line on the drawing is default lineweight, and the default is set at 0.25mm, I have the exact settings on different drawings but they dont have this display issue.
Can anyone shed some light on why this might be happening?
I found the issue was in the Pagesetup I had "Display plot Styles" checked on certain drawings that was causing the issue.
Thanks for the update. (It's always best when you find the solution yourself.)
