AutoCAD 2010/2011/2012
Distinguished Contributor
3 Kudos
Post 1 of 8
'Drawing file not valid'
1595 Views, 7 Replies
04-23-2012 07:12 AM
I received a drawing from a customer, via email. When I go to click on the name, I can see a postage stamp image of the drawing itself, but when I go to open it, I keep getting a 'Drawing not valid' error.
I get this message whether it's AutoCAD, or True View.
I looked through the properties of the program, I didn't notice anything peculiar that would stop it from opening up. I also made a copy of the dwg file and renamed it, thinking the original was write protected, still no luck.
Any ideas?
*Expert Elite*
1,219 Kudos
Post 2 of 8
Re: 'Drawing file not valid'
04-23-2012 07:18 AM in reply to: BillMazza
maybe your customer works with a AutoCAD relase that's newer than your's?
Compare it, and in case of my guess is correct your customer can save to an older DWG-format.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
3 Kudos
Post 3 of 8
04-23-2012 07:27 AM in reply to: Alfred.NESWADBA
Thanks Alfred,
That is a possibility, however, the drawing was originally created in 2008, and last updated in 2011.
We are currently using ACAD 2012 in our office.
*Expert Elite*
1,219 Kudos
Post 4 of 8
04-23-2012 07:30 AM in reply to: BillMazza
ok, when your customer does not use AutoCAD 2013 then you should be able to read all DWG-files.
So the next option: have you retried to receive the file with a new mail? Just to make sure that not the file-transfer through internet had some disruption.
What happens if you try the command _RECOVER instead of _OPEN, does that repair the database?
- alfred -
Alfred NESWADBA
3 Kudos
Post 5 of 8
04-25-2012 07:35 AM in reply to: Alfred.NESWADBA
We got a message from the customer that the drawing was saved as an AutoCAD 2007 file.
I don't know if I can do any type of recover function, if I can't open the drawing.
Everyone in the office has tried it, and cannot open it. Unfortunately I am not at liberty to contact their engineering staff myself.
3 Kudos
Post 6 of 8
04-25-2012 07:38 AM in reply to: BillMazza
When I have another CAD session open, and choose _Recover, I get a message that the drawing cannot be recovered. When I choose _Open, it gives me the 'Drawing not valid' message.
3 Kudos
Post 7 of 8
04-25-2012 10:09 AM in reply to: BillMazza
If possible, I would like to send this file to someone, rather then post it in the forum, to see if they can find a solution to the problem.
*Expert Elite*
1,219 Kudos
Post 8 of 8
04-25-2012 11:54 AM in reply to: BillMazza
look to PM
- alfred -
Alfred NESWADBA
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
