Hi all,
I'd like to know if there is a way to create a viewport with a hole in the centre. If this is possible, how would I go about it?
James
Solved by Alfred.NESWADBA. Go to Solution.
It is possible.
You can either make a "C" shaped viewport and make the gap as smaller as possible as shown below, or create a circular viewport and put a smaller circular wipeout (polygon shaped) at the center of it.
another option:
Drawing is attached, HTH - alfred -
Brill! Both are great ways to solve. Thanks so much for your help guys. I really appreciate it 🙂
James.
