AutoCAD 2010/2011/2012
Valued Mentor
9 Kudos
Post 1 of 3
Accepted Solution
Double click edit a block - Edit Block Definition dialog?
1876 Views, 2 Replies
05-07-2012 11:53 AM
On two machines... When you double click a block reference, the Edit Block Definition dialog opens. On one of the machines the applicable block is highlighted in the list just like you would want... you can then simply click the OK button to enter the block editor. But on the other it is not highlighted.
I tried switching to the out of the box profile and behaviour is the same.
Both machines, both PickFirst and DblClkEdit are set to ON.
Any ideas as to why?
I found the solution.  We had set QAFlags = 3 in a program... setting it back to 0 solves this issue.
QAFlags is an undocumented command.
I need to look into this further and perhaps write an error routine for our lisp customization.
Valued Mentor
9 Kudos
Post 2 of 3
Re: Double click edit a block - Edit Block Definition dialog?
05-07-2012 12:52 PM in reply to: mdhutchinson
New Member
0 Kudos
Post 3 of 3
05-30-2012 01:56 PM in reply to: mdhutchinson
Thank you!
I just spent the last 2 hours looking for the solution. What a weird one.
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
