I cannot edit by double clicking, move blocks or hatches, nor use the layer panel to edit the properties of layers the way I was able to a day ago.
1) Right-click menu options do not show up, such as Block Editor and Hatch Editor.
2) The Hatch Editor Panel shows up when a hatch is selected, however, the command buttons do not to work.
3) The Layer Panel does not reflect any layer selections.
4) Key short cuts do no work properly.
For example I cannot select an object and then type M then Enter to move it.
I have to type out Move then Enter and then select the object.
Similarly, C > Enter does not copy, and the Delete or Backspace buttons do not erase.
I have searched for solutions and have tried the following without any success:
DBLBLKEDIT - ON
ATTIA - 1
CUI - Double CLick Actions - ON
AcEAttEdit - Unknown because this is 2011 version
AFAIK - Unknown because this is 2011 version
Any help you could offer would be greatly appreciated.
Solved by Patchy. Go to Solution.
