AutoCAD 2010/2011/2012
Active Contributor
1 Kudo
Post 1 of 14
Distance Command and Rubber Band
1201 Views, 13 Replies
06-28-2011 03:49 PM
This has been driving me crazy since I upgraded to 2011.
When I use the distance command and pick the first point the rubber band line doesn't appear and then when I pick the second point I get a distance, but I have no way of knowing exactly where the points I picked landed.
I saw another post about the rubber band being black against the black background, but that is not the problem.
When I turn Otrack on I get the rubber band, but I don't like Otrack on because it causes other problems.
Anyone know how to get the rubber band to work the way it did before?
Thank you
Jim Dee
*Expert Elite*
473 Kudos
Post 2 of 14
Re: Distance Command and Rubber Band
06-29-2011 05:58 AM in reply to: jimmydee
Do you mean the DIST command or the MEASUREGEOM command and the Distance option? Have you tried both?
Active Contributor
1 Kudo
Post 3 of 14
06-29-2011 07:30 AM in reply to: rkmcswain
The DIST command is what I typically use for checking measurements but the MEASUREGEOM works similarly.
The lisp (getdist) and (setq pt (getpoint '(0 0) "Second point: ")) functions still works the way I want them to. I guess Autodesk forgot to break those.
Thank you for your response.
Jim Dee
*Expert Elite*
473 Kudos
Post 4 of 14
06-29-2011 07:41 AM in reply to: jimmydee
..... I guess Autodesk forgot to break those.
Is DRAGMODE set to "Auto"?
Active Contributor
1 Kudo
Post 5 of 14
06-29-2011 07:58 AM in reply to: rkmcswain
Yes - Drag mode is set to Auto.
Does it work the way I've described for you as well?
Jim
*Expert Elite*
473 Kudos
Post 6 of 14
06-29-2011 08:05 AM in reply to: jimmydee
Mine works fine in 2010, 2011, 2012.
I can replicate what you say if I turn Dragmode off.
*Expert Elite*
61 Kudos
Post 7 of 14
06-29-2011 09:05 AM in reply to: jimmydee
Dynamic Input (F12) = ON
Active Contributor
1 Kudo
Post 8 of 14
06-29-2011 09:45 AM in reply to: ToanDN
If I turn Dynamic Input on I still don't get the rubber band.
I have a Windows 7 computer running AutoCAD 2011 and I have tested this on another computer with Win 7 and ACAD 2011 and another XP computer with ACAD 2011 and both computers display the rubber band.
To test apples to apples I turned off all of the "Status Toggles" and they still get the rubber band and I don't.
12 Kudos
Post 9 of 14
06-29-2011 10:19 AM in reply to: jimmydee
Try _AUTOSNAP I have mine at 55, sounds like yours = 0
Active Contributor
1 Kudo
Post 10 of 14
06-29-2011 11:48 AM in reply to: SugarCAD
You are right, when autosnap is on the rubber band works, but I don't use Autosnap and I'm not sure what one really has to do with the other. I would classify this as a bug.
Thank you for your help.
Jim
Post to the Community
New Post
