AutoCAD 2010/2011/2012
Distinguished Contributor
oyy5408
Message 1 of 12 (553 Views)
Accepted Solution
Displyaing lineweight in Model Space.
553 Views, 11 Replies
12-07-2011 09:10 PM
How can I view the lines in butt joined styles instead of beveled or whatever you may call it.
Please have a look at the attached.
*Expert Elite*
Patchy
Message 2 of 12 (546 Views)
Re: Displyaing lineweight in Model Space.
12-07-2011 09:53 PM in reply to: oyy5408
You mean like this?
oyy5408
Message 3 of 12 (538 Views)
12-07-2011 10:30 PM in reply to: oyy5408
yes like that in the model space. how did you do that?
*Expert Elite*
Patchy
Message 4 of 12 (534 Views)
12-07-2011 10:38 PM in reply to: oyy5408
When you use Continuous linetype it will fillet the corners, pick a different linetype and it will butt joint.
oyy5408
Message 5 of 12 (525 Views)
12-07-2011 11:08 PM in reply to: Patchy
I tried using different linetypes (dashed, iso dash, double dash  etc.) and scaling them so that they look continuous, but it still looks filleted.
Is there something I'm missing
*Expert Elite*
Patchy
Message 6 of 12 (515 Views)
12-08-2011 04:20 AM in reply to: oyy5408
Use polylines.
oyy5408
Message 7 of 12 (508 Views)
12-08-2011 04:45 AM in reply to: Patchy
Please see attached.
It's a polyline, not using BYLAYER nor CONTINUOUS and I'm still getting the beveled ends.
Can you please show me how to do this step by step?
*Expert Elite*
Patchy
Message 8 of 12 (501 Views)
12-08-2011 05:11 AM in reply to: oyy5408
Command: PLINE
pick a point, w (enter) 1.58 (enter, enter)
*Expert Elite*
mathewk
Message 9 of 12 (487 Views)
12-08-2011 07:22 AM in reply to: oyy5408
...I tried using different linetypes (dashed, iso dash, double dash  etc.) and scaling them so that they look continuous, but it still looks filleted...
Patchy said Continuous, not "scale them so they look continuous". You have not said that you tries the continuous linetype.
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
oyy5408
Message 10 of 12 (480 Views)
12-08-2011 07:52 AM in reply to: oyy5408
Patchy said:
   "When you use Continuous linetype it will fillet the corners"
That's why I said I tried not using 'continuous' and 'bylayer' (equivalent to continuous as default), since I already have done them previously.
Patchy, I understand your method now, but is there a way to have lineWIDTH set to zero and adjust lineWEIGHT instead and still have the line show up with non-filleted edges?
Announcements
Need installation help?
