when i install autocad mech 2012 that time suddenly closed and installation failed
i attached log file..pls help me anybody
Solved by Alfred.NESWADBA. Go to Solution.
Look to >>>that info<<< about error 1603. With at least the difference that you have troubles with Framework 4.0 (not 3 like in mentioned in that message).
So go the following steps:
After a restart activate your Antivirussoftware and connect back to Internet, start at forums.autodesk.com and let us know, what happened .... 😉
- alfred -
