I have a strange issue happening.
Whenever I insert a block into my drawing fromt he Tool Palette, Autocad creates a Text Style and Dimension Style,both named Annotative. This happens on any drawing, with any block.
The funny thing is I can purge them after the block has been inserted.
They are NOT nested in the blocks. I have tried recreated the tool. Nothing seems to be working.
Anyone else have this problem?
I hadn't noticed it before, but what you describe appears to be "normal" behavior (2010).
The Annotative DimStyle and TextStyle "appear" (in a clean new DWG) when inserting one of my own blocks (a DB) from a source DWG that I have confirmed does not contain those styles.
Looks like theres nothing you can do about this. I wonder what the resoning is for it? And why no one has noticed this before. Guess I pay too much attention to detail.
Thanks for the replies!!
"Guess I pay too much attention to detail."
It's only "too much" until somebody needs it. (And it's just a matter of time until somebody needs it. )
Did this ever get solved? I can't believe it's been a problem for 10 years and nobody cares?
I've got the exact same problem, I've only just started noticing... classic insert doesn't do it, copying and pasting from another drawing doesn't do it, design centre insert doesn't do it... only inserting from tool palettes??
It’s only a problem if you choose it to be.
