Hi All -
I set up a new dimension style. Whenever I place a dimension it isnt respecting its properties and changes the Dim Style properties of that dimension to A$0. Any insight?
Thanks!
The "$0" (or "$anything") after a dimstyle name indicates a "child" dimstyle. These are created automatically for particular types of dimensions that require slight, individual variations from the "Parent" dimstyle, such as angular dims or radius/diameter dims (for example; to see others appear in your dimstyles list, create a few other types of dimensions).
These are steps:
1. Go to Dimstyle Manager and delete STANDARD dimstyle. Then if needed do purging
2. If you are using AutoCAD Mechanical, go to option and AM:Standard, change Scale and Dimensions options there.
3. Other way to change Scale is from command line AMSYMS and set your scale.
Hope ths will eliminate the $0 trouble
Also for AutoCAD Mechanical, you need to define scale area AMSCAREA to let the dimensions follow the scale (length wise or size wise) in the area defined
