Good day.
I am trying find all dimensions on my drawing, where the text has been over-ridden.
I tried to use the quick select tool for the search, had no luck at all.
Do you have any suggestions on how to do that.
Regards Mathew
Quick select is the way to go BUT it will be a little bit long winded. If you've overwritten the dimensions with numbers it shouldn't take too long, if you've overwritten with just letters it will take a while.
Select all your dimensions and then choose quick select
Scroll the the list you can select by until you find TEXT OVERRIDE
Change from EQUALS to WILDCARD MATCH.
Now in the wild card match put in *0* that will find any dimension which has been overridden with 0 anywhere in there.
I also suggest that when it has found those dimensions you move them out of the way somewhere, and then select the remaining dimensions
Do the same for numbers 1 to 9
Howard Walker
Here's an entry I made into my AutoCAD Notes:
DETECT MODIFIED DIMENSION: 2011.11.01.TE:
Invoke the DIMREASSOC Express Tool (or DIMREASSOCIATE, if you like typing out even longer words).
You can select all of the entities in the drawing, and DIMREASSOC will create a selection set of only those which have been changed, allowing you to see them more easily.
From Mistress of the Dorkness: “Finding Modified Dimensions in AutoCAD”: 2011-10-25
@hwalker wrote:Quick select is the way to go BUT it will be a little bit long winded. If you've overwritten the dimensions with numbers it shouldn't take too long, if you've overwritten with just letters it will take a while.
I did everything you suggested and thought of something that might make it even easier. Instead of assigning values from 0 to 9, simply search once for the value *.* (point), since this is the common character among all dimensions. By doing this, we were able to locate and select all the dimensions that were edited by text override
You can use "?*" for the wildcard search - matches any non-empty string. See:
https://www.cadforum.cz/cadforum_en/qaID.asp?tip=3832
Vladimir Michl, www.cadstudio.cz
May is ask why you want to filter out the dimensions with a text override?
If it is to remove the text override, just select all dimesions and type the contents as <>.
The <> always gives the 'original' value of measurement.
I always use this method for extra text options like <>mm to give an occasional dimension a units view.
Therefor the value changes when changing the associated object, but your override still remains.
Perhaps this might help you.
PWGSC for example does not allow Dimension Overrides. If you global reassign them using <> then you lose all information that has been input into these dimensions, and thus have to start from scratch. So you want to find, isolate, cut the contents and paste it as a text entity. Just one good example.
